Blurry screen (LCD or logic board issue?)
I got this Macbook Air for repair and I'm still not a 100% sure if this is the LCD problem or logic board problem.
Watch here: https://www.youtube.com/watch?v=oym6NBeN...
Everything is blurry and it's like the frames do not refresh and stay there longer. The effect is worse when the display brightness is low (shown in the video)
Customer told me there may have been a water damage on the keyboard.
External monitor does work normally.
What I already tried:
- I cleaned the motherboard with isopropyl-alcohol
- reconnected everything
- opened the electronics under the display and wiggled with cables (no clear image)
- re-installed mac os
Nothing of the above helped and I'm inclining to think it's more likely a LCD issue. Can I be more sure before ordering an replacement?
Also the two white dots on the screen suggest a mechanical damage?
Thanks for any tips.
Ist dies eine gute Frage?
4 Kommentare
Lets inspect the LVDS connector on the logic board. With the battery first disconnected take a sharp zoomed in picture of the connector with the cable installed as well as with the cable disconnected and one of the cables end showing the pins post all three here Bilder zu einer vorhandenen Frage hinzufügen so we can see.
von Dan
Thanks Dan, I've uploaded the pictures. This is the best I can do. I think the connector looks fine.
von martin.fialka10
How does the solder joint side look? Post that if you can.
von Dan
Looks ok too. I added the photo.
von martin.fialka10
