Zum Hauptinhalt wechseln
Das Xiaomi Mi 4 ist die vierte Generation von "Mi"-Smartphones der Xiaomi Technology Company und ist zum Zeitpunkt seines Erscheinens mit der neuesten Smartphone-Technologie ausgestattet.
59 Fragen Alle anzeigen
The headset on my phone is not disappearing.
The headset symbol is not disappearing from the upper task bar. What could be the problem. 2. My MI4 is not working with some 4glite network sim. I will be very grateful if you could give me useful answers to my questions.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Try updating the software on your phone to the latest version. Annoying “glitches” like a tenacious headphone icon are sometimes caused by an outdated software version. Also, see if doing a full factory reset of the phone’s operating system doesn’t help. These can be done in the phone’s Settings.
If you phone is not working with a certain 4G network, then it may need a PRL (Preferred Roaming List) update to make sure it’s connecting to the right cellular towers. This may also be done in the phone’s Settings.
War diese Antwort hilfreich?
Bewertung 0
Hello,
The problem you are describing is likely caused by liquid damage on your dock (the part that handles the speakers, microphone, antenna and charging port).
You can check if this port was in contact with water by tearing down your phone using this guide, and spoting any water signs : Xiaomi Mi 4: Akkufachdeckel tauschen
If you’re not sure about that, you can always bring it to a repair store where they will test and make sure the problem is coming from here.
Cheers !
Bewertung 0
Antwort hinzufügen
Shiyanbola tunji wird auf ewig dankbar sein.
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 32
