Zum Hauptinhalt wechseln
Aufpolierte Version des iPhone 3GS mit schnelleren Verarbeitungsgeschwindigkeit. Die Reparatur geht ähnlich wie beim 3G vonstatten und braucht nur einfache Schraubendreher und Hebelwerkzeuge. Modell A1303 mit 16 oder 32 GB Kapazität mit schwarzer oder weißer Kunststoffrückseite.
1502 Fragen Alle anzeigen
No success after replacing battery, what next?
Hi I dropped my iPhone and there is a small crack in the screen and on the back case.
The screen didn't break and the phone was still working but it stopped charging and wasn't recognised by the computer.
Eventually the battery died and the phone hasn't turned on since.
I have replaced the battery with a brand new one, what I wanted to ask is:
Neither batteries will charge, I assume that there both carry a charge, albeit a small amount to power the device so is this a logic board issue? or the dock connector?
Ist dies eine gute Frage?
Bewertung 1
2 Kommentare
okay, I will replace the dock connector next guys, thanks.
Surely the new battery I bought contained enough charge so I am curious as to why it wont switch on - even with a faulty dock connector?
(update) iPhone is able to power on from USB plug into the wall, but reboots after two minutes, and switches off when unplugged.
von
it should have..if all your connections are correct and there was no other damage. use a multimeter to measure the charge in your batteries..
von
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Yes, replacing the dock connector is definitely the way to go, and it's a really easy fix. Here's a link to the guide.
All you need is:
the dock connector
a Phillips #00 screwdriver
a small scution cup
and a spudger
Good luck!
iPhone 3GS Dock Connector Bild
Produkt
$19.99
Spudger Bild
Produkt
Spudger
$3.99
Phillips #00 Screwdriver Bild
Produkt
$5.49
War diese Antwort hilfreich?
Bewertung 3
The rebooting after 2-min problem also happens if u put in a wrong battery. i.e. if u put in a battery for 3G in 3GS instrument. Double-check the part number and it's origin
Bewertung 1
Antwort hinzufügen
no way wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 10
Letzte 30 Tage: 14
Insgesamt: 2,972
