Zum Hauptinhalt wechseln
Der Mac Pro (Anfang 2009) kam im März 2009 auf den Markt. Er führte erstmals die Nehalem Architektur von Intel in die professionelle Apple Desktop Reihe ein, und verfügt über ein leicht neu konzipiertes Inneres, das auch bei den 2010 und 2012 CPU Updates beibehalten wurde.
200 Fragen Alle anzeigen
Harddrive bays (1 thru 4) are not recognized in Disk Utility
My Macpro 4,1 does not show any of the Harddrives in the 4 bays, however when you look at the Sata/Sata Express in the system report (Serial-ATA Device Tree) Intel ICH10 AHCI.
A work around I have removed the dvd drive and booted the system from one of the Sata connections (it works, for both the connectors). How do I check if the Harddrive bays are getting power from the main board?
Any Help is greatly appreciated!
Thank you in advance.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Most likely your power supply has failed. Keep in mind your PSU has a a few power legs. The drive power lines likely are dead. I would get a junker drive so you can take the connector off to wire it up so you can measure with a DVM the power feeds. Here’s the wiring diagram from the cable side:
Here, you’ll need the connector wired to plug into your drive backplane.
2009 - PSU - 661-5011
2010 - PSU - 661-5449
War diese Antwort hilfreich?
Bewertung 2
3 Kommentare:
Dan: This is Awesome :)
Just wanted to point out, I replaced the power supply and still had no ‘Joy’ on the hard drives - bays.
However I will do as you suggested and measure the voltages and compare with above diagram.
Are the drives (per) connected in serial? i.e., if the first does not have power the subsequent will not fire up?
Thank you for your suggestion, will report back what I find.
Cheers!
-k
von
Dan:
Good News and Bad;
Bad - The SATA connection seems to be not working
Good - There is power to the drive :)
Need help to troubleshoot the SATA connection! - can I do this without removing the motherboard?
Thank you in advance for your assistance.
Cheers!
-k
von
Sorry to hear the data side is the problem. This system uses a North and South bridge design. As such the South bridge chip is responsible for the SATA ports.
You'll need to find the schematics and board views to trace out the paths. I've never needed to go this far on the Mac Pro's.
von
Antwort hinzufügen
Karpentor wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 162
