Zum Hauptinhalt wechseln
The HP Chromebook 14 G4 features a 14-inch HD display and is only 0.7-inch thick. A Chromebook is a laptop or tablet running the Linux-based Chrome operating system.
My screen is not lighting up - but image is displayed.
I have a HP Chromebook 14 G4. When powered on, the screen stays black [no backlight] but you can see [using flashlight] that the image is there. How can I determine if this is a LCD, lcd cable, or system board issue?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
I work in a school district that has this same problem with this same model. The problem is the screen cable. For some reason it works its way loose. If you just snug the cable back in and tape it down it should work fine again.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Tommy Stiles wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 13
Insgesamt: 892
