Zum Hauptinhalt wechseln
Die Wi-Fi Version von Apples iPad 6, erschienen im März 2018. Erhältlich mit 32 und 128 GB Speicher. Ausgestattet mit einem 9,7" Retina Display und einem 64-bit A10 Fusion Prozessor.
147 Fragen Alle anzeigen
Apple Light Mod Question
Hey everyone,
i am an active member to the ifixit forum, however I have a question about a mod I’ll be performing. I’ve done several logo light mods to the iPhones, however there is no mod available for the iPad. I am able to remove the IPad 6 logo and have it 3D printed so it would be transparent so I can install leds behind it and the logo would light up. My question though, where would I solder the LEDs power source? Would it go somewhere on the LCD Panel or somewhere on the board such as the backlight filter? I only want the logo leds to turn on when my screen is lit and I’m using it. After it’s locked, the logo would turn off.
can someone lead me where I would solder the logo leds on the IPad 6 to make this mod possible? I already have the transparent logo and the leds working with my meter, and the ground to any screw, just lost on where I would solder the positive lead side to the iPad for current only when iPad is being used…
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
You could try to solder the leds to a ribbon cable that could take power from the battery, like other mods for the iPhones, if you had a cable like so from a broken mod kit.
Update (03/05/2019)
Run a jumper wire from the logo to PPLED_OUT_A that drives 20volts to the LEDs should work.
War diese Antwort hilfreich?
Bewertung 0
3 Kommentare:
It’ll work off battery but I want it modified so it only works when the screen receives power and shuts off when you lock the screen. I was told you can solder to the L4601 anode filter which would make this mod work
von
It'd probably require a specific splice to the LCD power to have it work the way you need it.
von
I’ve found a solution I think will work. Running a jumper wire from the logo to PPLED_OUT_A that drives 20volts to the LEDs should work
von
Antwort hinzufügen
Daniel wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 98
