Zum Hauptinhalt wechseln
The SanDisk Cruzer Glide is USB flash drive with a retractable USB plug. It comes in a variety of storage capacities with a black and red plastic case for all models.
11 Fragen Alle anzeigen
Is this Flash Drive fixable?
I accidentally droped the laptop that this was plugged in to… the cover for it split and when we went to plug it back in, it wasn’t showing up on the computer. I feel like this can be fixed easily since the connection to the motherboard is still intact… It’s just not showing up on the laptop.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
It probably cant be fixed unless you go to a professional so unless you have information you need on it then give up. Or if your lucky you can play around with it and it will work. Good luck
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
I agree that it probably can be fixed but easily…no. It’s hard to say from the pictures but when a USB drive is physically damaged, it usually means some traces on the circuit board are damaged. This can be fixed but it requires micro-soldering and that makes any DIY repair unlikely.
Here’s an example of the type of damage I am referring to.
If you value the data on the drive, you could send your USB Drive to a micro-soldering repair specialist.
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
Brett W wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 34
Insgesamt: 241
