USB IC same as iPad Air?
I have tried searching for parts for a iPad 5 that doesn’t charge anymore. Tested the battery and lightning connector and they were fine. I was wondering if someone know if the IC’s are compatible with iPad Air or Air 2, because those parts I can order. If they are not compatible I will decline to repair this iPad 5.
Problem it is having:
When you plug in the USB side first and then the lightning side it does not charge.
When you plug in the lightning port first and then the USB side it will start charging for some strange reason.
Ist dies eine gute Frage?
