Zum Hauptinhalt wechseln
Die Wi-Fi Version von Apples iPad 6, erschienen im März 2018. Erhältlich mit 32 und 128 GB Speicher. Ausgestattet mit einem 9,7" Retina Display und einem 64-bit A10 Fusion Prozessor.
147 Fragen Alle anzeigen
Busted LCD after screen repair
Ok what’s with this?!? (Look at the picture) I am super duper gentle and super patient when it comes to replacing the screen on an iPad! What takes 30min for some it takes an hour and a half for me because I’m that careful.. Which is why I’m scratching my head over here! I replaced the broken screen on this iPad 5th gen and once I was about to put everything together I did the routine check and the screen was damaged!!! How the heck is this possible??? I turned off the device and detached the lcd and reattached it again (I thought maybe I placed it in wrong?!?!) but still the problem was there… This is an LCD issue right??? RIGHT?!?! I mean I know the answer but I need some reassurance for some peace of mind here! I’m still scratching my head on how this even happened?!?! How did this happen?!?! Anyone???
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
It rely looks like an LCD problem. I would feel confident enough to return it and say that its broken. Buy a new screen and see if it works then you know if it was an LCD problem. If the new screen doesn’t work then its probably the logic bored.
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
NOOOOOO NOT THE LOGIC BOARD
von
Antwort hinzufügen
wm_alvarez wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 94
