Zum Hauptinhalt wechseln
Reparaturanleitungen und Demontageinformationen für Android-Handys aller Formen, Größen, Farben und Marken. Hol dir alles, was du zum Reparieren brauchst.
33480 Fragen Alle anzeigen
I did something to fix my phone
I found in the internet that after you dropped your phone into the water, you need to dry it off then bury it inside a container with an uncooked rice. Is it gonna work? What should I do if that’s not gonna work?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Hello Ashley
You can not repair a terminal damaged by liquids without opening it and clean the plate completely with isopropyl alcohol + 90º.
Charging or turning it on will only damage the interior.
Repairing a wet terminal without opening it is like operating a patient with just caresses and good words.
Electronics Water Damage
War diese Antwort hilfreich?
Bewertung 2
Hi @gachaz
for first, if your mobilephone is damaged by water, it will be damaged forever. Inside of mobilephone, there is some special protective layer, which protect your phone against corrosion caused chemical reaction between air and PCBA’s material. This protective layer can be removed by water and after the layer is removed, your mobilphobe - PCBA - will not be protected against corrosion. Also, the firts what you have to do after your mobilephone was in water, is remove battery, SIM, SD Card and protect your phone against shorts caused from battery to PCBA, but there are a lot of condenser, which are having charge, so you will be lucky, if the mobilephone will be fine, but not for a long time.
Anyway, if you want to dry your phone, you have to use special - silica gel - which having best absorption of water/humidity.
See attached images below.
Your mobilphone will be fine only for recover your necessary data - it will die anway.
Bewertung 0
Antwort hinzufügen
Ashley wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 55
