Zum Hauptinhalt wechseln
Apple kündigte am 9. März 2015 an, dass das Retina MacBook 2015, Modell A1534 am 10. April herauskäme. Es hat eine neue Unibody Konstruktion und beinhaltet ein verbessertes Trackpad, Tastatur und Retina Display.
281 Fragen Alle anzeigen
MacBook 12" 2015(820-00045) no display, no chime, no image
Hello, @arbaman @reecee @refectio and other experts!
Recently I received a dead MacBook 2015 12”. When I connect charger, no chime no image, no backlight.
  1. I tried measure every power line with multimeter, but I found missing voltage only on PP5V_S0SW_LCD, PP5V1_S4SW and PP1V05_S4SW lines
  2. I use my ThermoCam and compared the thermo image with good working board but images look the same. So I think there is problem only with image and backlight (maybe)
  3. I disconnect everything and connected a known good display but does not help
  4. I preventatively replaced U4700 but no change
On the internet I found, than a lot of people have same issue with this model. Is here any way how to fix?
board number is 820-00045
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare
Did you press the re-set button on the battery connector?
von
sure man, also tried smc reset, reconnect battery
on the board is not present
EDP_BKLT_EN
EDP_PANEL_PWR
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
I haven't much experience on A1534 boards unfortunately, I have a dead board around for a few months now but haven't had the time to get deeper into it. Do you have an adapter you can try to plug into an external screen to help you point in the right direction ? The missing enable for backlight might be your issue indeed.
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
sure i tried connect external display but no image :)
on the board are not present
EDP_BKLT_EN
EDP_PANEL_PWR
von
Sadly, I think your best option is to replace the logic board MacBook 12" Retina (Early 2015) Logic Board.
MacBook 12" Retina (Early 2015) Logic Board Bild
Produkt
$249.99
Bewertung 0
Antwort hinzufügen
Tomas wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 7
Insgesamt: 989
