Zum Hauptinhalt wechseln
The Grand Prix was updated for 2004 on a revised version of the GM W platform and was unveiled at the 2002 Chicago International Auto Show on February 7, 2002 as the Grand Prix G-Force Concept.
19 Fragen Alle anzeigen
turns over but will not fire
my car has gas in it does not stall or hesitate was running just fine until a couple days ago it died while idling started right back up but when i parked it when back out a while later it wont start turns over but wont fire
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare:
2002 grand prix.replaced fuel pump.it kicks in but wont start and backfires?any help?
von
If there is old gasoline in the tank it may have turned into water. Try adding some dry gas to the tank.
von
Einen Kommentar hinzufügen
2 Antworten
Check for spark at plug wire, if no spark check ignition fuse if ok check coil pack if ok you may have a broken timing belt
War diese Antwort hilfreich?
Bewertung 0
I had to replace the fuel pump in mine.
Bewertung 0
Antwort hinzufügen
mkazee81 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 3
Letzte 30 Tage: 32
Insgesamt: 2,219
