My display image is all a mess!
My Problem is much worse!
Please Help Me!
Ist dies eine gute Frage?
Please Help Me!
What does the image on an external display look like? If its clean then you’ll need a new display assembly, if the external is also messed up your logic board has a problem.
Either way this is an expensive repair!
Sadly, I suspect you banged the black clutch cover area which pressed against the cable and the T-CON board damaging it which would be the cause of needing a new display assembly. Here’s a view of the connections just behind the cover:
Its one of the two fatter cables that you damaged.
War diese Antwort hilfreich?
how should I get it done, from apple store or repair from someplace else?
how much will that cost me & will it create problems if I don't get it resolved soon?
I would bring it to an Apple Store. As far as cost its around $700 just for the part.
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 49
