Zum Hauptinhalt wechseln
Die 6. Generation des Surface Pro, erschienen im Oktober 2018. Erhältlich in Schwarz und Platin. Modell Nummer: 1796.
Can I use the display unit of the Surface pro 5 for pro 6?
Hi,
can i use the Display of the pro 5 to fix my shattered Pro 6 Display?
Ist dies eine gute Frage?
Bewertung 3
1 Kommentar
I'm going to give a tentative "yes" with the caveat that I'm not speaking from direct experience.
Looking at pictures of replacement screens for both the Pro 5 and Pro 6, the cabling looks to be identical. The specs (resolution, physical dimensions, etc) for the screens are also the same. I also found part number "LP123WQ1 SP A1" being sold on eBay as a replacement screen for the Surface Pro 6 *AND* the Surface Pro 5.
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
No you can’t, the Surface Pro 5 and Pro 6 displays have different touch controllers and are not cross-compatible.
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
I have installed the pro 5 display on a surface pro 6 without issues. I’m not sure sure where you got your info from but they are 100% cross compatible.
von
Antwort hinzufügen
ykf kaanf wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 3
Insgesamt: 1,958
