Zum Hauptinhalt wechseln
Die Wi-Fi Version von Apples iPad 6, erschienen im März 2018. Erhältlich mit 32 und 128 GB Speicher. Ausgestattet mit einem 9,7" Retina Display und einem 64-bit A10 Fusion Prozessor.
Ipad won't connect to home wifi
All Apple devices will not link up to home wifi. Changed password wifi and still no connect. Rebooted system and reset Apple products network system and no connect. Advices wifi password is wrong. All other android devices connected no problem.
Ist dies eine gute Frage?
Bewertung 1
1 Kommentar:
"No connect" is too vague; more details and information is needed. Are you getting an error message? Is it not seeing the network? You say "All Apple devices" but specifically call out just an iPad 6; is it just a single iPad or are there other devices that can't connect? Can they connect to other wifi networks?
von
Einen Kommentar hinzufügen
2 Antworten
Hi,
  1. Go to settings (app)
  2. Then select “General”
  3. Scroll down and click on “Reset”
  4. Now click on “Reset Network Settings”
  5. Go back to “WiFi”
  6. Select your WiFi
  7. Re-enter password
War diese Antwort hilfreich?
Bewertung 0
common problem check ur wifi conection with another apple device if conects then safe mode ur ipad and delete the most recent app u installed or update it and then boot up as normal also reset ur wifi
Bewertung -1
Antwort hinzufügen
roroeow7 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 5
Letzte 30 Tage: 14
Insgesamt: 608
