Zum Hauptinhalt wechseln
Das Google Pixel 2 ist Googles zweites Flagschiff -Smartphone, es erschien am 17. Oktober 2017. Das Smartphone ist mit einem 5" AMOLED Display ausgestattet und kann mit 64 oder 128 GB Speicher bestellt werden. Erhältlich ist es in drei Farben: Schwarz (Just Black), Weiß (Clearly White) und Blau (Kinda Blue).
65 Fragen Alle anzeigen
Dropped Phone in Water
I dropped my pixel 2 in water and it was fine in the beginning. No short outs or issues. Plugged it in the charge when I went to bed. I woke up at 4 am and it wasn’t working. It still vibrates and my alarm went off, but the screen would not come on. I am also able to answer calls. Touch screen and sound work. I just do not think the screen can come on.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Water damage can cause all kinds of problems, some of which may not be fixable without a board replacement.
Assuming your device doesn’t have permanent damage, the important thing is to try and get all the water out of the phone. If you haven’t already done so, turn the phone off and put it in a bag of rice (or silica gel packets, if you have them) for a day or two. This should help to draw any moisture out of the phone. Simply leaving it out in the air or trying to shake out the water will not generally work to remove all of the moisture, and it doesn’t take very much to short out a circuit trace.
This may not be enough to get everything working, but it should definitely be one of the first things you try whenever you have a water-damaged electronic device.
You should seriously consider having a repair shop look at it, even if it starts working after it is dried out. Corrosion on the circuits is progressive and will eventually kill the board if it is not properly cleaned and the damage repaired.
War diese Antwort hilfreich?
Bewertung 0
It would be better if your phone is open witch you can doErsetze die Displayeinheit deines Google Pixel 2 you don’t have to open it fully just a little bit is good. Don’t use rice it will get lost in your phone.
Bewertung 0
Antwort hinzufügen
David Crowell wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 7
Insgesamt: 1,352
