How to clean this PC.
Delay and very slow Is there a way to wash the machine or get rid of the garbage inside the machine?
Ist dies eine gute Frage?
It could be a number of reasons that it is slowing down. Common problems are file and registry clutter, poor cooling or an old or failing hard drive. As far as clutter I would back up important stuff and do a factory reset. It can do wonders performance wise. Now if it is getting too hot and throttling you will need to pop it open and clean the fans and possibly repaste the heat sink. I couldnt find a teardown guide on here but did locate one at this address https://community.acer.com/en/discussion... Lastly, the hdd. A failing drive can cause similar performance issues. You could download a free disk benchmark to test its performance. If it is failing just follow the same teardown guide and replace the hdd. If it doesnt already have a solid state drive, get one. You will see your performance go up by leaps and bounds.
War diese Antwort hilfreich?
If you haven't done any cleaning before,I don't think you should do it yourself,because this can easily damage it.
you should ask experienced friends to help
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 95
