Zum Hauptinhalt wechseln
The TI-83 Plus is a graphing calculator released in 1999 as an upgrade to the TI-83.
What is this missing component on the logic board?
Opened up my TI-83 Plus calculator (its an older model: 8TA837MB-30B). The board says TI-83 (F) on it. When I opened it, an inductor in the L6 slot was missing. This is located near the I/O jack to connect to the computer. A commercial picture of the board is shown below with where the L6 inductor is supposed to be. I just can’t find out what value of that inductor is so I can replace it. Any help would be much appreciated. I’m doing this more for soldering practice rather than just buy a new board and replace it. Thanks!
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare
@timothydavis288 Hi, missing components aren't always a bad thing, is your calculator functioning properly? If so, I wouldn't worry about it. If it's not working, could you please explain what exactly is going wrong?
von
I tried plugging it up to the computer and it didn't receive a program I sent to it. I assumed that was the problem. It worked fine on another model. Opening it up showed that there was a missing component and so I deduced that that was the culprit.
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Does it run fine? If so, I wouldn’t worry about the inductor. But, if you’re doing soldering practice, it’s probably best to use a completely broken board (e.g fried motherboard from a desktop, vcr mainboard, etc)
Good luck!
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
That does help! But no, it does not recieve programs from the computer. So I deduce that the inductor is the problem.
von
Antwort hinzufügen
timothydavis288 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 23
Insgesamt: 278
