Why is my battery not charging or recognized?
My ACER Iconia 10” tab mod B3-A40 often get a battery overheating msg ask to "remove battery". In time would random abruptly turn off while in use. Then frequency turn offs increased & only able use while was plugged in. In more time inoperable. Turned off and would boot. I bought a brand new battery from an auth ACER parts dealer. Still not work. While plugged red light below camera lens lit up but not boot. I charged for hours & nothing. Somehow by tinkering it turned on, showed low battery 3% & when plugged in the battery icon showed it was in charge mode (with lightening bolt) but went from 3% to 2% with constant warning battery low to plug in. By simple observation microusb charge port seems ok not loose. My battery is not accepting a charge or it is not recognizing that a battery is plugged in as I would have assumed that a new factory battery would have some pre-charge in it if not full. And of course my question is why? or what could be the possible reasons? Is it the charge port or circuit board stuff?
Ist dies eine gute Frage?
Punktzahl 0
Kommentare:
Have you tried charging your tablet with a 2000 mAh charger? Charging with low amp adapters may not charge your battery efficiently.
von
Einen Kommentar hinzufügen
