Early 2009 Display Assembly on Mid 2009 system
Hi,
I was wondering if the display assembly from a late 2008 to early 2009 would fit on my Mid 2009 MacBook Pro 15” 5.4.
The connectors seem to be identical.
Thanks for your help :-)
Ist dies eine gute Frage?
4 Kommentare
Your systems specs: 13" MacBook Pro 2.53 GHz Core 2 Duo (with SD slot)
von Dan
Are you up to replacing the LCD panel alone? Or do you need to replace the full display assembly (case damage).
von Dan
I was planning to replace the full assembly. I don't have the tools to remove the glass, so buying a used assembly is the cheaper choice.
von Arne Büsing
Then you'll need the correct assembly part as there is enough differences in the part to prevent the substitution of the full assembly.
von Dan
