Zum Hauptinhalt wechseln
Das März 2015 Update von Apples 13" MacBook Pro Retina Display, Modell A1502, bietet fifth-generation Intel Core i5 und i7 Prozessoren der 5. Generation und führt den Force Touch Trackpad ein.
1005 Fragen Alle anzeigen
Liquid damage, Now running slow with overactive fan.
Had a water bottle next to my bed and accidentally knocked it over in the middle of the night onto my mac.
The following day I opened it up, my track-pad was over-responsive, wifi didn’t work at the time either. Wifi and trackpad are working again since I let it air out. However, the slow processing speed has not changed.
There was some corrosion noted near the track pad connecter/cable on one side, otherwise there was no other obvious signs.
The fan is over-working also present on start up.
Can anyone point me towards some resources? I am a novice with Mac repairs, however am comfortable replacing my own display for my iphone if this helps with my skill level.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Hey Matthew,
Sounds like a Sensor is damaged. This causes the Computer to think its running a lot hotter than it actually is and throttles down the CPU and runs the fans high. You can use a Sensor Checking software to see what sensor it is.
Sensor check software: http://www.tunabellysoftware.com/tgpro/
If it’s the trackpad sensor you will have to deal with prying out the battery carefully for replacement, otherwise its going to be a Motherboard repair, it shouldn’t be too big of a deal for any repair shop offering micro soldering. As long as they know what they are doing :P
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Matthew McClelland wird auf ewig dankbar sein.
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 29
