Zum Hauptinhalt wechseln
Kompaktes elektronisches Schlagzeug von 1996.
Whooping sound. Is this repairable?
When powered on, the unit emits high pitched whooping sounds (see video). I opened it up, hoping to see something obvious, but everything seems fine for a 25yo device. It does this both on battery and on Wall plug. Suggestions?
I don't have access to an oscilloscope, just a soldering iron, multimeter and limited understanding.
Ist dies eine gute Frage?
Bewertung 0
5 Kommentare
Try the multimeter on the speaker cones or output, and see if the voltage output fluctuates.
von
Thanks for the reply. I tried it and saw that it indeed fluctuates. My meter is digital, so exactly how much is hard to say, but I saw over 6V values. What does this mean?
von
Maybe a damaged amp circuit? It could be thinking there's a signal, and amplifies to max, then resets. Or maybe interference from another device?
von
Yes, that sounds about right. there appears to be done sounds, but that gets mangled and only one channel works. Could it be a capacitor or something? Like replace one component and it works again? Is there a way to test components without removing them? There are no visual effects (leaks, discolouration, smells)
von
You can add some ferrite beads to the wiring. May not fix it, but it should help prevent interference.
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
@okeribok  that does not sound like interference. It sounds like a bad power supply (MOSFET) or bad power amp. We’ll have to see the boards etc. to help you further. Attach some good pictures of your board to your question. Bilder zu einer vorhandenen Frage hinzufügen
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Okeribok wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 10
Letzte 30 Tage: 22
Insgesamt: 597
