Why my Samsung TV won't turn on?
My Samsung TV won't turn on there's no red or green lights either. What can i do?
Ist dies eine gute Frage?
Hi @gutierrez1719 ,
What is the model number of the TV?
Was there a storm or power outage before the TV failed to turn on?
Have you checked that the power outlet that the TV is connected to is still working OK?
You may have to totally disconnect the power from the TV and then remove the back cover off the TV and visually inspect the boards for any obvious damage e.g. burnt out components etc, especially the Power board.
The power board is the one which connects to the power inlet socket on the TV.
There is also a fuse on the power board that you might want to check is OK if you have access to an Ohmmeter.
If you see any component damage post some pictures back here for more help.
Here's how to do this.
War diese Antwort hilfreich?
First, you need to ensure you have power running in your circuit:
1) Does your TV connect directly to a wall outlet or do you use a splitter or a surge protector?
If direct connection into the wall, check to see that your wall outlet has not had had the short circuit trigger. Simply plug in another device into the same outlet and see if it works.
If it plugs into a splitter or surge protector, plug it into a direct wall outlet to see if the surge protector is the problem.
IF your TV is plugged directly into wall outlet AND wall outlet has power AND your TV does not turn on at all, then we would need to do some troubleshooting.
How do you turn on the TV? through a remote or do . you use a button? Could your TV be in standby mode?
What is year of manufacture, size, name and model of TV?
Do you happen to have the user manual? It does have troubleshooting questions at the end of the user manual.
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 89
1 Kommentar
I also got similar problem but mine the light is no with no sound no picture please assist
von Patience Mzila Mpofu
