Zum Hauptinhalt wechseln
Das Apple iPhone 5s wurde am 10. September 2013 angekündigt. Die Reparatur dieses Geräts ist ähnlich wie bei den Vorgängermodellen und erfordert Schraubendreher und Hebelwerkzeuge. Verfügbar mit GSM oder CDMA mit 16, 32 oder 64 GB in silber, gold und space grau.
3531 Fragen Alle anzeigen
OTA may have failed, leaving phone with "No Service," activation fails
iPhone 5s/32gb which was on the latest IOS version
  1. Phone started showing “No Service” where the operator logo used to be. Allowed an hour or so to go by as I was in no hurry to get calls. No change after around an hour. Restarted the phone. No service.
  2. It was late in the evening, so I left the phone off all night, powered on in the morning, got a signal, made an outgoing call, received a call. A few minutes later, “No Service.”
  3. Rebooted the phone, got a system dialog “Cellular Modem Update Failure” or words to that effect. The support page suggested power cycling etc and if all else fails, to connect to iTunes and fully restore the phone.
  4. Did all that. During this process, the “No Service” text gained a triangle with an exclamation mark. After this point, iTunes refused to proceed since it could not get Activation Data from the phone.
I have reason to believe a cellular modem update failed the previous night, leaving the modem firmware in an inconsistent state.
For whatever reason, iTunes does not seem to restore modem firmware?
Took the phone to Apple service. Without even looking at it, they asked for 2/3 the price of an iPhone 6s 32gb to replace the 5s.
Any pointers? Is it possible to get this phone back up to the point were I can use it at least as an iPod?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Your phone’s issue sounds more like it’s originating with your wireless service than the phone’s firmware.
Your phone may need a PRL (Preferred Roaming List) update to ensure that it’s connecting to the right cellular towers. This can be done within your phone’s Settings.
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
After some research and talking to the service provider, I have given up on this repair.
The phone is stuck in an activation/unhelpful error message/reboot cycle.
In hindsight, I should not have followed the instructions on the Apple support page. The advice there put the phone into this mode where it isn't recognized as a valid device. I could have removed the SIM and just used the phone on wifi only.
Moving on.
von
same happened to me and I found a solution
Bewertung 0
1 Kommentar:
Care to share? Thanks.
von
Antwort hinzufügen
Sanjay Mehta wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 105
