Zum Hauptinhalt wechseln
Fix Your Stuff
Right to Repair
Parts & Tools
Herausgegeben am 25. September 2015. Model A1687/A1634. Die Reparatur des 6s gestaltet sich ähnlich zu denen früherer Generationen; benötigt werden Schraubenzieher und Hebelwerkzeuge. Verfügbar mit GSM oder CDMA / 16, 64 oder 128 GB / Silber, Gold, Space Grau oder Roségold.
2164 Fragen Alle anzeigen
Any tips on getting the hex nut out of the phone?
How do I get this hex nut out. My bit just keeps spinning over it
Ist dies eine gute Frage?
Bewertung 0
Kommentare:
Try a smaller bit.
von
Already did. Didn’t work
von
Not sure if iFixit sells it, I'm sure they do, but there's actually a bit that is shapped like a hexigon, I have a screwdriver that's H2.5 (Hexigon 2.5mm) and it's a perfect fit.
von
Einen Kommentar hinzufügen
3 Antworten
Hilfreichste Antwort
Use one that’s about the same size, but is slightly smaller and still fits over normally. This usually works to deal with stubborn ones.
If you’re finding it’s still being stubborn, you will need a driver with more torque. The issue is it was tightened more then it should when the phone was assembled at the factory. This isn't the end of the world but you will need to match the force used to have a chance at removal.
War diese Antwort hilfreich?
Bewertung 1
Kommentare:
I did and it didn’t work
von
If you have that H2.5mm then you can try to put like a thin rubberband over the screw itself, and see if that adds into the empty space making your bit spin around it to add some grip to the twist.
von
Thr rubber band thing has never worked for me @neos_hle. What usually does is a slightly larger (or smaller) screwdriver to help fit the hole better.
That said plyers are likely to damage the board beyond repair, so it's the only viable option for getting this out as a last resort.
von
What that screw is is a stand off screw. Since its not a common screw driver at all, use a very small flathead screw driver. If it helps please give this answer a like, it would be much appreciated!!!!
Bewertung 0
Bewertung 0
Kommentare:
Antwort hinzufügen
Owen Baker wird auf ewig dankbar sein.
Statistik anzeigen:
Letzten 24 Stunden: 1
Letzten 7 Tage: 1
Letzten 30 Tage: 10
Insgesamt: 125
