Zum Hauptinhalt wechseln
HP Laptop konzipiert für den Einsatz zu Hause und im Home-Office.
1034 Fragen Alle anzeigen
How can I find out what can be upgraded in my HP Pavilion laptop?
Hello, I have an HP Pavilion 17 inch laptop and I’d like to know if it’s upgradeable at all but an issue I’m having is Windows and HP list different model numbers, Windows calls it ar0xx and HP calls it ar050wm and I can’t find any information on the internals using either model number so I was hoping someone here could help. Thanks.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
1 Kommentar
Well, Now the BlueTooth has failed, is there a way to replace that?
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
https://support.hp.com/us-en/document/c0...
Above are the specs for your laptop.
It should have came with 8GB of DDR4 ram you can upgrade it to 16GB of DDR4 ram. you can also change from a HDD to SSD to incress speed.
War diese Antwort hilfreich?
Bewertung 2
5 Kommentare:
Thank you for the help, I really appreciate it.
von
Quick question, I would like to upgrade the memory but I'm not sure what exact type I need, I've tried using the compatibility tool on Amazon when searching for memory but it always says it isn't sure if it's compatible.
von
Well, Now the Bluetooth has failed, Is there a way to replace the Bluetooth module?
von
Antwort hinzufügen
Gary McCoy wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 7
Insgesamt: 314
