Why is my Asus ac1900 not working at all
After working perfectly I had to unplug My Asus rc-ac1900 after has no lights nothing no signal anything please help the id a 130$ router and I need it
Ist dies eine gute Frage?
Hi @gamerbug ,
Did you mean Asus RT-AC1900?
Did you turn off the router and the router power supply outlet before removing it from the power outlet?
If there are no lights showing on the router, have you checked the power outlet that the router is connected to is OK?
If it is have you checked that the router’s power adapter output is OK (+19VDC 1.75A)?
Have you checked that the Power button on the back of the router is operated?
If the outlet and the adapter are OK and the button is operated and the device is longer covered by the manufacturer’s warranty, you’ll have to open it up and inspect the board for any obvious damage to the components around the power input connection.
If you do open the device and find something or if you’re not quite sure, post some pictures back here.
Here’s how to do this.
War diese Antwort hilfreich?
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 22
Insgesamt: 5,124
2 Kommentare
Hi im also having problem with my asus ac 1900 router i try to fix the power button and i saw some small copper or gold? im trying to remove the spring i dont know how to put back these small coppers any help.. thx
von yuusuke28
Router running with outdated or old firmware version may start problem after sometime and some time router running non stop longer time need to refresh it. just reset router and setup it again. find reset guide-https://mikrotrik.com/reset-asus-router-...
von David Silwa
