Zum Hauptinhalt wechseln
Dokumentation und Anleitungen für die Reparatur des am 22. September 2017 veröffentlichten iPhone 8. Modellnummern A1863, A1905.
873 Fragen Alle anzeigen
Screen change keyboard don't show up
Okay, here is the weird situation.
I changed the screen of an iphone 8, everything works perfect, customer came back, he cannot edit or add contacts because the keyboard wont show, but on everything else keyboard pops up.
Anyone know what this is?
I suspect a software issue since keyboard is showing every where else.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Try a hard reset first (See: Erzwungener Neustart des iPhone 8)
However I think you are correct, a software fault is the most likely cause of this and that would be fixed via an update/restore.
Is the customer on the beta program? A friend of mine is and he could only answer incoming calls, his dialer wouldn’t work until the following update was available.
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
Actually thanks for this, but it was me having a mayor brainfart.
I just had to double click the homebutton and exit all programs.
von
No worries, if only all fixes were that easy!
von
Antwort hinzufügen
nicolay.94 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 2
Letzte 30 Tage: 3
Insgesamt: 62
