Zum Hauptinhalt wechseln
Die Wi-Fi Version von Apples iPad 6, erschienen im März 2018. Erhältlich mit 32 und 128 GB Speicher. Ausgestattet mit einem 9,7" Retina Display und einem 64-bit A10 Fusion Prozessor.
149 Fragen Alle anzeigen
What is this part? And What does it do?
Sadly during my removal of the screen this part came off with it. I want to know what it is so I can replace it.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
That’s the wifi antenna.
War diese Antwort hilfreich?
Bewertung 2
7 Kommentare:
There's one on each side I'm assuming their both antennas that work together?
von
@redport You're right, they serve signal amplification to two different frequencies, I can't tell exactly which is which but with one missing you lose signal to a full range of devices, you need both to be there in working condition.
von
from the looks of it iFixit only sells 1 and not the other. They sell the left but no right...?
von
@arbaman Thanks for the help Found that its the GPS antenna. Appreciate your help, thank you!
von
Should be ok doesn't look like the antenna was ripped or the cable teared. That is the adhesive foam under it that had separated. You can use a bit of scotch tape to hold it down.
von
2 weitere Kommentare anzeigen
Antwort hinzufügen
RedPort wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 69
