Stripped 1.1mm screw above home button.
Hi all, I’m really hoping someone will be able to give me a hand here, so the 1.1mm screw on top of the home button of my iPhone 7 plus is stripped, and absolutely refuses to get out. I have tried the superglue technique (superglue the driver to the screw) and am worried it may have even glued the screw to the bracket. The only solution I can think of is to bend the home button bracket on either side of the middle screw, and use the bracket itself to remove the screw from the home button. I have ordered a new home button bracket either way, does anybody have any other ideas? Should I even attempt what I am proposing?
Thanks in Advance.
Ist dies eine gute Frage?
1 Kommentar
Easiest solution as Chris suggested is carefully bend the bracket on both sides upwards push the hole thing through the hole then just straighten it and screw it into the new screen
von c9679
