Zum Hauptinhalt wechseln
HP Laptop konzipiert für den Einsatz zu Hause und im Home-Office.
677 Fragen Alle anzeigen
HP pavilion x360 15 CroXXX phantom ethernet connection
My laptop doesn’t even have an ethernet port and its showing an ethernet connection. It has been causing problems so I need this gone. Anyone have this issue before and know how to fix it?
Update (05/16/2019)
Here are the devices that show in device manager
Ist dies eine gute Frage?
Punktzahl 0
Kommentare:
Hi @connor2003
How are you?
some things you can try.....
updating the computer BIOS,
what do you see in device manager on network adapters?
von
I posted an update, please check it out.
von
are you able to uninstall the Realtek usb gbe family controller from device manager?
if you are not using it, consider removing the drivers by checking it when you remove the device from device manager.
von
@connor2003 all of it looks like wireless connections, not ethernet. What model is your computer?
von
Hp x360 convertible 15-cr0037wm
von
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
I see a VPN device driver installed. Uninstalling the vpn software should fix the problem.
War diese Antwort hilfreich?
Punktzahl 1
Kommentare:
Disabling it is the farthest I can go (still didn't fix it) Removing it would require entirely reinstall my vpn software.
von
You can go into control panel then go network and sharing Center then go to network adapter's and see what it's called when you right click the ethernet adapter and go into properties
von
was this always a problem or is this something recent if so i would try using recovery setting to go back to a restore point if you are using windows 10 use the search bar and type recovery then open system restore follow the prompts and choose a date and time as far back as you can this should reset the setting back this will not effect your files
Punktzahl 0
Antwort hinzufügen
Connor wird auf ewig dankbar sein.
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 11
Insgesamt: 96
