Zum Hauptinhalt wechseln
Repair and disassembly guides for Kenmore Microwaves.
Microwave shuts off intermittently, already replaced door switch assem
I have a model 401.80082700 serial 725MM00044. Intermittent problem. Microwave goes through heating cycle and then totally powers off…no display, no light, no power. After 15-30 seconds the display comes on and instructs to press clock and reset time of day. After doing so the microwave is fully functional and may operate several times before powering off again. Occasionally the display appears fainter than normal, esp the center of display. I have replaced the door switch assembly but after several days the intermittent problem has returned. What do you think? TY
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 3
1 Kommentar
After much delay and frustration I ordered and replaced the control board…..works great…..thanks for your recommendation!
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Sounds like the problem is the control board, not the door assembly. Try replacing the main controller circuit.
Good luck!
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
I have the same problem with my Kenmore microwave. Is this the part I need? https://www.searspartsdirect.com/product...
von
Hilfreichste Antwort
There are two parts to that door switch, here they are on your model along with how to test them:
https://www.repairclinic.com/RepairHelp/...
Bewertung 2
Antwort hinzufügen
Ken Thome wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 17
Insgesamt: 1,257
