Zum Hauptinhalt wechseln
Reparaturanleitungen für Fahrzeuge der Marke Isuzu.
39 Fragen Alle anzeigen
Isuzu Gigga V10 engine torque settings
hey i need assistance with torque settings for an Isuzu Gigga V10 engine . the engine number is 10PEI-164725
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 3
5 Kommentare
Tariro Ngove tell us what Giga this engine is out of. V10 Diesel?
von
hie, what exactly do you mean when you say what is it out of so i know what to ask my mechanic
von
As far as i know the vehicle is a an Isuzu truck and it needs an engine orvall done, its an Isuzu Gigga and the engine is a V10
von
Tariro Ngove Isuzu Giga is a model,that is where I got lost. My mistake. It was made for the Japanese market and it appears as if they were also used in Isuzu C and E model trucks
The engine you need the data for would be :
ISUZU 10PE1-S Engine
Type: 10 cylinder V type OHV direct injection
Bore x Stroke: 127x 150mm
Displacement: 19001cc
Compression Ratio: 18.0:1
Power output: 265 kw @ 2300 rpm (360hp)
Torque:1245 Nm @1400 rpm
von
help me for the parts catalogue of Isuzu 10PE1 engine . thanks a lot.
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Tariro Ngove  here is the document with all the engine torque settings. Isuzu 10PEI V10 Torque settings Let us know if this will work or if your mechanic needs more information. Welcome to iFixit and we’ll try and find whatever we can
War diese Antwort hilfreich?
Bewertung 5
8 Kommentare:
thnak you, if more information is needed ill get back to you. thank you once again.
von
hey please may you also assist me with:
1) injector pump timing degrees
2)crank shaft jornal size mains and big end specifications
3) crank oil clearance
4) filter numbers
5) clearance numbers
i hope i stated everything correctly, hoping to hear from you soon
von
hie, im failing to download this manual
von
Tariro Ngove do you get an error message when you try?
von
Thank you, managed to download
von
3 weitere Kommentare anzeigen
Antwort hinzufügen
Tariro Ngove wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 8
Letzte 30 Tage: 51
Insgesamt: 1,895
