Zum Hauptinhalt wechseln
A Touchscreen Notebook that was created by HP in 2014 for computing and processing.
6 Fragen Alle anzeigen
Laptop won't connect to wifi
It didn't have my hp model as an option but it's a 15-ba049ca . It shows WiFi networks that are available and allows me to put my password in to connect but then it like stops. The available networks disappear and then reappear again but still won't let me connect. I have no idea how to fix this and would appreciate some guidance on what to do!
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
4 Kommentare
When you check the Network with your phone or another device, do you see the same signal intensity? like the same bars, if you see low signal in your computer and high signal in your phone, that can be a loose connection with the Wi-Fi antennas to the Wi-Fi Card.
von
It is the same intensity or my phone has one less bar. Is that still the same issue?
von
Maybe you need to reinstall the wireless driver.
von
I've done that unfortunately, I also updated them and still nothing
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Hi Nicole,
  • First you need to download the latest drives but not install.
  • Now completely uninstalled the current driver and run something like Ccleanerto clean up any traces.
  • Reboot and then install the new driver.
  • Why this way? If there is a corrupt setting or the like re-installing, as expalined above, will just perpetuate the problem.
  • Let us know how it goes.
War diese Antwort hilfreich?
Bewertung 1
Hilfreichste Antwort
Hi Nicole
Have you tried to use a usb wireless dongle and try? it could be that your internal network card could be faulty, or a dry joint contact on the board.
Regards
Mckenzie
Bewertung 1
Antwort hinzufügen
Nicole wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 412
