Zum Hauptinhalt wechseln
Das Samsung Galaxy Note 4 ist ein Smartphone, das im Oktober 2014 heraus kam. Die Modellnummer des Galaxy Note 4 ist bei der amerikanischen Variante eine der folgenden: SM-N910, SM-N910A, SM-N910T, SM-N910V, oder SM-N910R4.
256 Fragen Alle anzeigen
Why won't my display come on
My phone has been experiencing a problem with it’s screen, half the screen will freeze and the other will continue to work normally, I usually fix this by turning off the phone and removing the battery and putting it back in.
I did so recently and dropped it mid battery swap(I’m clumsy) The screen wouldn’t come back on but still sensed my pen and the buttons still light up. I tried taking the screen off and reseating the connectors, but doing so hasn’t worked
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
This sounds like your average Samsung. so I want to start by guiding you into the basic state of recovery.
GOOGLE- Turn off the Galaxy Note 4 completely. Press and hold the Volume Up and the Home keys together, then press and hold the Power key. When the Note 4vibrates, release both the Home and Power keys but continue holding the Volume Up key. When the Android System Recovery shows on the screen, release the Vol Up key
But from there if nothing happens , because i do not have the same phone i cant be much assistance to you.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Mally- -Wally wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 42
