Zum Hauptinhalt wechseln
Das iPhone 6 Plus mit dem 5,5 Zoll Display ist die größere Version des iPhone 6 und seit dem 19. September 2014 auf dem Markt.
1525 Fragen Alle anzeigen
iPhone 6 Plus not powering on after being off for a long time
So one day I left my phone in a drawer and forgot to power it off fully. It’s been months before I found it again and when I plugged it in, nothing came up on the screen. I left it overnight and still no response. I know the charger is good because it works on my other phones and the phone had worked previously before I left it in the drawer. I’ve tried hard restarting to attempting DFU mode and nothing. This phone has had battery drain issues even after a factory reset so I’m not that surprised that the battery was bad but I was expecting it to boot up. Anything else for me to try?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
If the battery was fully drained and totally dead the logic board will not send any power to the battery
War diese Antwort hilfreich?
Bewertung 1
5 Kommentare:
So is there anything that I can try or not?
von
Replace the battery.
von
Boost the battery with a power supply or one of those plug in battery charger boards if it keeps depleting below a certain tolerance and wont charge again then replace battery or if battery life isn't good... if the new battery doesn't fix it then replace tristar, thats the order I normally do it in cos sometimes the battery is perfectly fine it just gone too flat that one time and just needs a boost. Sometimes even just holding the power button and plugging the cable in and keeping the button held has worked for me but I might have just imagined this and the battery might not have been that dead lol
von
I replaced the battery and it seemed to fix it. Thanks!
von
Glad you were able to fix it! Sorry I myself hadn't replied, I don't tend to the forums very often!
von
Antwort hinzufügen
jimmysofat6864 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 3
Insgesamt: 318
