Zum Hauptinhalt wechseln
A laptop computer series by HP. The numbers and letters that follow "G60" usually indicate what retailer sold it and what hardware it contains.
5 Fragen Alle anzeigen
Can't access documents on my HP G50-126NR, says security problems.
it fell and would not turn on. 5 months later i charged it for a cuple of hours and when i turned it on , it gave me a black screen with pointer. i ctrl-alt-del and restared it set it up to safe mode everything came up but took 10min or so to load then then stoped working and said it faild to created a security ___. then it went black with pointer. i turned it off and on it went striagt to my setting skipping the log on page. took another 10min or so to load the start and when i click the document program it says windows explorer stoped working( i did not click on any internet window) is it fixable?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
char, from what I read on here it sounds like you are having software and not hard ware issues. I would start off with reinstalling the Windows OS. The black screen with a pointer only, as well as all the other errors, seem typically of windows having issues with some of the system files. It is possible that the "fall" of your computer causes some read/write issue on the hard drive. Reformat it when you install windows. Good Luck and I hope this helps. BTW the windows explorer issue is not related to internet explorer, those are separate explorer's ;-)
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
char wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 288
