Zum Hauptinhalt wechseln
The second generation HTC One—dubbed the HTC One (M8)—features a dual flash and the new Sense 6 UI, and was released March 25, 2014.
201 Fragen Alle anzeigen
I dropped my phone (heavily) and now it is on constant vibrate
Phone constantly vibrates even when off after a drop from the top of the stairs to a slate floor (surprisingly everything including the case is fine. I assume this is a hardware fix. Any ideas where to start?
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
Thanks for this fast response. I did wonder exactly that but then thought why would a vibrator be on? It must be getting volts to work surely if it was faulty it wouldn’t work or be intermittent. Unless I guess it is switched on the earth side and a short to earth. It would be hand to look at a circuit diagram. really appreciate the response thank you
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Hopefully just a bad vibrator.
If you are planning to open the device, buy a replacement vibrator just in case because opening the device and putting the device back together is fairly complicated due to the plethora of ribbon cables it has.
A replacement vibrator can be bought online on sites such as eBay:
https://www.ebay.com.au/itm/Vibrator-Vib...
Here is a guide, the main board may need to be removed to unplug that vibrator:
HTC One M8 Hauptplatine Austausch
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
Richard Foulkes wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 10
Insgesamt: 438
