Zum Hauptinhalt wechseln
Verständliche Reparaturanleitungen für alle tragbaren Tablets von Apple. Reparaturen erfordern Wärmezufuhr und vorsichtiges Hebeln.
5755 Fragen Alle anzeigen
Charging issues on Ipad devices
lately we have been getting in iPad air’s and iPad Pro’s with charging issues we start with replacing the charging port then if that doesn’t work we try the battery and then the charging IC but we have noticed that none of these are fixing it. Has anyone else had similar issues and if you have were you able to find a fix?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
I can’t speak for the Pro but on the iPad Air, the problem is usually with the charge port or the battery. By charging IC, I presume you are referring to the Tristar IC. However, I have not seen much success when changing that IC. When the problem persists, it is usually the PMIC. However, they are a more challenging repair and the replacement cost of a PMIC can be quite high so not all customers agree to the repair for such an old device.
War diese Antwort hilfreich?
Bewertung 4
1 Kommentar:
What is the charge for this PMIC repair ? I am having a similar problem.
von
Antwort hinzufügen
Jonathan Pegues wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 223
