Tv wont turn on.
my samsung tv doesnt turn on as soon as you plug it in it blinks 2 twice tree times then stops and if i press the power button it just blinks once. tv model is UN40D6000SFXZA
Ist dies eine gute Frage?
Samsung does not really use post blink codes. However, the two blinks usually relate to the power supply. You can try this first. Disconnect the power cord from the outlet, then press and hold the power button on the TV (not the remote), for at least 10 seconds. Then wait a few minutes and plug the TV back in and press power once. If that does not work, you will have to remove the back of your TV and check the boards. It might help if you post some images of all of your boards so we can see what you see. Use this guide for that. Check the voltages going to the board as well as on the connector from the main board cable and the LED’s. The first check I’d try is to disconnect the cable from the power board to the main board. See if that turns the backlight on and keeps it on. Let us know what you find.
War diese Antwort hilfreich?
i think i will ask again later since i cant get to the back of the tv since the screws for the stand are striped and i dont think i can actually remove the back without removing the stand first.
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 204
