Converting a Fusion drive to two separate drives.
Greetings all;
I purchased a used subject iMac above that has a weak Fusion drive system. What I want to do is replace the SSD blade with a 2 TB version and the hard drive with a 4 TB SSD. In the long run, use the SSD blade as the main macOS drive and the other SSD for data.
Which 2 TB SSD blade would work for the iMac and which 4 TB SSD would be most suited for the iMac?
I already took care of the RAM.
Thank you for your advice.
Ist dies eine gute Frage?
