Zum Hauptinhalt wechseln
Veröffentlicht am 16. September 2016. Modelbezeichnung 1660, 1778. Verfügbar in den Versionen: GSM oder CDMA / 32, 128 oder 256GB / Rosé Gold, Gold, Silber, Mattschwarz oder Hochglanz-Schwarz
2264 Fragen Alle anzeigen
iPhone 7 GPS does not lock or track location
What replacement part(s) are required for fix the GPS on iPhone 7, where it does not lock location?
The WiFi works fine.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
3 Antworten
There are many possibilities. Have you done the obvious? Check settings,make sure apps have access all the time just to make sure? Have you factory eraser the phone and set it up as new to eliminate typical software variables?
Does the gyro sensor and accelerometer work? You can check this in the compass app usually. See if the compass spins accurately. Does your phone switch rotations when turned? These sensors help track movement of your phone as well. But you definitely need to rule out software issues if you haven’t already.
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
I've done all the software options. I've done a factory reset and the issue still persisted. However, the issue is intermittent so I'm assuming the gps component is loose or on the verge of failure.
I'm looking for suggestions on the hardware in terms of parts that may be failing.
von
There are various reasons as to why GPS won’t work as intended on your iPhone 7. Among the widely known culprits include network connectivity or signal issues, software bugs or apps glitches on GPS-enabled apps, faulty updates on GPS apps and/or iOS.
Other issues with GPS have been linked to environmental factors like a big tree, giant infrastructures, walls or tall buildings that can obstruct that signal strength between the iPhone and the sky.
Possible solutions and workarounds to deal with iPhone 7 GPS errors
Solution 1: Perform a soft reset
Solution 2: Turn off LTE
Solution 3: Reset Network Settings
Solution 4: Update iOS
Last Resort: Factory Reset
In worst cases, the problem is directly tied to hardware defect like a damaged or dysfunctional GPS chip on the iPhone. Alternatively, you can take your iPhone to an authorized service center for hardware assessment and/or repair.
Bewertung 0
2 Kommentare:
von
@calisoldier83 Better take your phone to an authorized service center and check out if the problem is in the gps component itself, especially if you're not familiar with disassembly and do not know how to put them back. Good luck.
von
It might just be an update, if so you should just wait. Apple makes mistakes along the road.
hAHhah whoops sorry for that joke
Bewertung 0
Antwort hinzufügen
calisoldier wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 617
