Zum Hauptinhalt wechseln
SCREEN SIZE 46" (117cm), 16:9 TV SYSTEM Digital: DVB-TAnalog: B/G, D/K, I,L,M Year: 2012-2013 http://www.sony.com.sg/electronics/support/televisions-projectors-lcd-tvs/kdl-46hx855/specifications
19 Fragen Alle anzeigen
Why is my tv showing vertical lines on hdmi and tv but not on the menu
Hi,
my tv (sony bravia KDL-46XBR45) is showing vertical lines, all evenly space, but only on hdmi and tv, not on the menu screen.
here are some images
https://i.ebayimg.com/images/g/3s8AAOSwO...
https://i.ebayimg.com/images/g/RT0AAOSwi...
is there anything i can do?
Ist dies eine gute Frage?
Bewertung 2
3 Kommentare
Hi,
Did you try different HDMI port, different HDMI cable, different signal source e.g. DVD player, different input source e.g. AV or component video to see if you can isolate the problem?
What have you tried?
von
@jayeff none of the ports work (av, hdmi, tv) they all show the same lines, apart from the menu screen
von
Did you find out the fix? I also have thos problem. Evan when i go on youtube on the app webbrozer the picture is perfect except the video box in the middle of the screen has the same lines.
von
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Hi,
Here’s a link to the video troubleshooting flowchart from the service manual for the TV.
Following the chart using the symptoms you describe indicates a possible FBA board or board connection problem.
p.49 in the manual shows the location of the board and p.63 shows the part number.
The board may not be the problem it is only a possibility
War diese Antwort hilfreich?
Bewertung 2
Hi, I had the same problem, and what it worked for me it was changing the image settings so on I had some HDMI ports on Vivid image, Cinema Image; and when this problem happened the only port that didn’t have the lines problem had the Personalized settings, so I changed the other ports to personalized image and the lines where gone:
1- Go to image settings
2- Change the image to Personalized
Hope it works for you as well.
Bewertung 0
Antwort hinzufügen
Giancarlo Amico wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 10
Letzte 30 Tage: 57
Insgesamt: 6,210
