Why are all break lights out?
When pressing on break pedel, none of my break lights illuminate?
Ist dies eine gute Frage?
As mentioned earlier, there is a mechanical switch by near the break foot pedal arm. It could be disconnected/faulty/broken. The other option could be a fuse that needs to be replaced. Check your fuse box. The first thing you should do before you go changing fuses is to pull the light out of the brake light housing and check the brake lights with a multi-meter. You can also use a multi-meter to check the fuses to make sure they are still working.
War diese Antwort hilfreich?
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 35
1 Kommentar
Hey KK.
Could be a simple switch at the top of the brake pedal, just not sure without more info on your vehicle. What year and model is that?
von Tony
