Zum Hauptinhalt wechseln
Echo SRM-225 Trimmer. This model replaced the SRM-210. The most common repairs for this device are straight forward and can be done quickly.
Motor runs great but head won't spin? Help!
Why won't the head spin?
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
I had a brush cutter attachment and hit an unmovable object. Now the head spins freely. I took the head off and say that the flexible drive shaft had become detached. I managed to grab the end of the shaft with a long tweezers and reattach to the head; but I don’t see any pins or other devices to hold the shaft in place to the head.
von
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Hey Keitha.
Three things.
The threads on the drive shaft are stripped. If that’s the case the head will not stay on the shaft, and both parts would need replacement; or
The drive shaft itself could be damaged or broken. Replace the drive shaft only, if this is the case; or
The clutch may be worn out or damaged, etc. In most cases it’s easier and not terribly expensive simply to replace the clutch, if this is your issue.
Hope this heads you in the right direction. Good Luck!!
War diese Antwort hilfreich?
Bewertung 2
Head won't spin until I lift it up and then it spin
Bewertung 0
Antwort hinzufügen
keitha.stinnett wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 29
Letzte 30 Tage: 108
Insgesamt: 4,530
