A1708 / EMC 2978 - Dieses MacBook wurde Oktober 2016 als Einsteigermodell seiner Klasse eingeführt. Es kommt mit den klassischen Funktionstasten, sowie zwei Thunderbolt 3 Anschlüssen und einem Intel Core i5 Prozessor.
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
3 Kommentare
Rarely does a cap go on its own. There is often a cause are you sure you are not fixing the symptom and not the root issue here?
How about giving us some background. Apple has a few extended warranty programs for your system (I think there are five now). So before you start altering things it may make sense to see if there is an issue you can claim to get this fixed for free.
I purchased the device in late 2016 in the UAE and the machine worked wonderfully. About three months ago the device was in stand-by mode and I did not use the device for two days and when I tried to start it did not work the device. I thought the reason might be the battery and already changed the battery and the operation of the device but there was a depletion of the battery was discharged quickly to turn off the device after three days and did not work. I opened the device to see what the problem and found this piece in this way
3 Kommentare
von Dan
Thank you for your quick response
von ammar_m_ali
Did you check to see if this was valid? 13-inch MacBook Pro (non Touch Bar) Battery Replacement Program and get it fixed under it? There was a parts issue also involved here.
von Dan
