Zum Hauptinhalt wechseln
Scientific calculator by Casio with 252 functions and full dot matrix display. It also features a Replay function and seven variable memory.
repairing of shift button in calculator
how to repair shift button in calculator
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar:
What's wrong with it? Not working at all? Did you spill anything on it? Did you open the calculator up to look inside? Did you try to clean the contacts yet?
von
Einen Kommentar hinzufügen
1 Antwort
  1. If you have had this calculator for some time it may be a hardware problem where there is a bit of graphite from the button on the board stopping it from receiving the input carefully clean if it comes apart or use contact cleaner.
  2. If it is a multi function calculator try going through the modes and get to to RAD or check the second function priorities. If none of that works hard reboot by taking out the battery.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Hasnain Ahmed wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 12
Insgesamt: 3,297
