Phone is powered on, but the screen is black
I have an iPhone 6 that had a mashed sleep/wake button that was no longer able to move. The phone was powering on but the screen would stay black (not even a back light). I’ve replaced the button/ribbon cable thinking that it was stopping it from waking the screen.
The new sleep/wake button and ribbon cable are working (iTunes recognizes the device is in DFU mode after doing the hard reset with the sleep/wake button and the home button) but the screen is still staying black - even after doing a recovery update in iTunes.
I’ve tried using a few cracked screens as a testing device to see if they light up but still have the same results.
Is there another trick to try, or is this down to a failed chip?
Ist dies eine gute Frage?
4 Kommentare
Thanks for the tip.
As it turns out, I can see the faint image on the screen when I shine a light down it. Would trying another screen work, or is this more than likely the fuse?
von Bill Shannon
If you have tried multiple screens that you know should light up, then no. I believe you have ruled out screen issues. If you have the equipment, the good news is this can be fixed by soldering across the two pads where the fuse used to be.
von Jeff
Thanks Jeff! Unfortunately I haven't worked myself up to micro-soldering yet and it seems the shops in the area that used to do it are shutting down due to lack of business. I'm getting busier with phone repairs now, but not quite to that point.
von Bill Shannon
No problem glad I could help! It's not an easy repair by any means...
von Jeff
