Why does my replacement screen nog dit?
The iPhone is not bend. How can i make IT fit?
Ist dies eine gute Frage?
check the top of the screen to see if there is a gap between the screen and the frame. sometimes you may need to realign the screen while putting the clips up under the frame so it sits flush at the top. if it sits flush at the top with no gap, it’s likely an issue with either the screen, or frame, the frame being more likely.
also especially for an iphone 6 series, check for a bend in the frame, if the frame bends upward it could cause less space between top and bottom and screen won’t fit in that instance. if it bends downwards too far you may break the screen while installing it. should be able to carefully bend the iphone 6 frame with your fingers back into place.
War diese Antwort hilfreich?
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 56
1 Kommentar
It looks like the edge of the display is damaged. Where did you get the part?
von Dan
