Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
A1418 / EMC 3069 / 2017 / 3,0 GHz Quad-Core i5, 3,4 GHz Quad-Core i5 oder 3,6 GHz Quad-Core i7 Prozessor. Erscheinungsdatum: 8. Juni 2017.
97 Fragen Alle anzeigen
Thunderbolt ports (USB-C) no longer working
I just upgraded the HDD with a 1TB SSD and the RAM to 32GB. Did everything according to the ifixit guide and now the 2 USB-C (TB) ports don’t work. Tried re-installing the OS on the SSD, tried the old HDD still the ports don’t work. Tried to align them more properly like other people say but to no avail. Everything else works just fine. Any suggestions?
Ist dies eine gute Frage?
Bewertung 0
Kommentare:
@geegor - You do realize this system does not have USB-C compliant ports. So can you tell us what you are trying to plug in.
von
@danj I am sorry, i meant the Thunderbolt ports. I am trying to plugin a thunderbolt hub (EPICO type-c hub pro II) and an Universal Audio Apollo Quad (silver) that is Thunderbolt 2 but i connect it to the imac with a TB2 to 3 adapter. As mentioned earlier, everything was working fine before the upgrade and both the hub and the audio interface work perfectly on my MacBook Pro 14,1
von
@geegor - OK, let's backup here. What happens when you plug the TB2 to TB3 adapter directly into the iMac's TB3 port with your audio adapter, does that work?
von
no, nothing works. I don't have a TB3 device except the hub.
von
So the TB2 to TB3 adapter and your audio unit directly plugged into the iMac's TB3 port does not work - Is that correct?
I suspect your ports power service is damaged. You'll need to use a power meter in-line with your device Satechi USB-C Power Meter to see whats happening.
von
12 weitere Kommentare anzeigen
Einen Kommentar hinzufügen
EINFACH ALLE TABS ÖFFNEN
RAM Upgrade Kits für Mac
Kits kaufen
Genügend RAM
für alle Tabs
Kits kaufen
3 Antworten
Hilfreichste Antwort
Once you get the logic board out following this guide iMac Intel 21.5" Retina 4K Display (2017) Logic Board austauschen you’ll need to compare it to a good board referencing Steps 11 & 12 here: iMac Intel 21,5" Retina 4K Display 2017 Teardown. Focus on the two TI chips CD3215C00 USB-C port controller (light blue). These often get damaged
iMac Intel 21.5" Retina 4K Display (2017) Bild
Anleitung
Schwierigkeitsgrad:
Moderat
iMac Intel 21.5" Retina 4K Display (2017) Logic Board Bild
Anleitung
Schwierigkeitsgrad:
Schwierig
1 - 2 hours
War diese Antwort hilfreich?
Bewertung 1
Kommentare:
Thanks Dan! The problem though is that i will need to get hold of another logic board that i know it works well. Maybe as a last resort before giving it to a local repair center is to buy the Satechi USB-C port meter...
von
You could also have a bad TB3 to TB2 adapter which would be cheaper ;-} Thats why I wanted you to first get the meter so you can tell which is at fault.
Do you have another TB3 device to plug directly into the systems TB3 port?
von
you mean TB3 to TB2 i guess. The adapter works fine on my laptop.
Other TB3 device no...just the TB3 hub that i mentioned that also doesnt work on the imac. On the laptop it also works fine...
What should be the reading on the USB-C Voltage meter? 20V?
von
The chip is also a limiter. So when you plug in a power supply it won't over voltage the logic board (when used in a MacBook Pro). Here it is powering the USB-C ports connected devices.
von
Hey guys, long time no see. So after all the troubleshooting that i tried, i found somebody who is doing repairs on macs. He got my imac and said that the TB controller chips or something like that are burned. After 3 weeks i got the machine back. I changed the HDD to an SSD, installed everything and guess what...TB ports dont work again...they work ONLY with the Satechi tester. Like nothing ever changed...
The repair store is closed today, but i will contact them on Monday and see...
I cant believe this ?!?!?
von
1 weiteren Kommentar anzeigen
Just a thought. I noticed you didn’t mention reverting back to your previous memory upgrade levels. Have you tried that?
Bewertung 0
Kommentare:
Hey prop man, what do you mean by previous memory upgrade levels? To try with the old RAM chipset?
By the way i tried with both the original HDD and the new SSD, tried NVRAM and PRAM and SMC reset and run Apple diagnostics (no problems found-everything fine). The thunderbolt ports are being displayed as normal on the system report as well.
von
I just installed 32 gigs of ram and 1 tb ssd in my imac and have the same issue. Worked before installation and now not working. Any more updates on this?
I am going to take it back to my tech guys, but it seems weird that the same thing would happen.
How much ram did you put in?
What type of ram?
Bewertung 0
Kommentare:
32GB of Kingston RAM i think
2TB of Samsung SSD
One tech guy that i took the imac to said that i probably connected a lightning bolt cable for charging on one of the ports and i "blew it up" ?!?!?
He (according to him) repaired the computer by installing new TB controller chips !??!? but he didnt fix anything, I told him that there's no way that i connected a charging cable. The computer had the same problem when i brought it at my place...
I opened the imac and didnt see any "soldering" or traces of something changed in the board. I contacted him again that its not working and we never arranged a meeting since then. I think i got scammed . He insisted again that i connected a charging cable to the ports ?!?!?! i got so angry
I am still using 1 port with the Satechi TB tester and everything is fine. I also told him that - it doesnt make sense that the ports work with the tester but dont without it...
von
@George Anagnostopoulos - Sorry to hear you got ripped-off. Where do you live maybe we can aim you to a better person.
von
Did you every figure out your issue with this?
von
Antwort hinzufügen
geegor wird auf ewig dankbar sein.
Statistik anzeigen:
Letzten 24 Stunden: 3
Letzten 7 Tage: 15
Letzten 30 Tage: 62
Insgesamt: 636
